When running and testing recipes, it is critical to have the ability to choose how far back the recipe should pull or sync data. Without this, integrations can work with data that is no longer relevant causing chaos to your systems. When sending out forms, adding contacts, and tracking expenses across apps, deciding when to move data can be important. With a “Since” parameter, you can choose how far in the past to select data from using an exact date or a set amount of time back.
In this video, you can see how easy it is to set place in time a recipe should start:
https://www.youtube.com/watch?v=_h9ESmR2bzA
Move the right information at the right time with the “Since” parameter in Workato.
