API management (APIM) has never been more important as the role of APIs in modern business continues to expand. By exposing their APIs, organizations can open up more revenue channels and level up their products by securely sharing data with customers, but proper monitoring and security are key.
Here we share the key concepts of modern API management as well as best practices to maximize the benefits and minimize the risks of exposing APIs.
Why API Management is Important
API Management enables organizations to effectively manage, secure, and monitor their APIs, which are essential for facilitating communication between different software applications. Organizations that employ modern API management see the benefits fast.
- New Revenue Channels and Secure Data Sharing: By exposing APIs, organizations can open up new revenue channels. For instance, in banking, APIs can be used to open fixed deposits or check account balances, leveraging data flow from apps and consumers to build intelligent and personalized experiences. This also allows for secure data sharing with external partners and customers.
- Real-time Compliance: Exposing APIs enables organizations to migrate from legacy batch integration processes to modern real-time patterns. This is essential for modern automation use cases and ensures compliance with regulatory requirements by enabling interoperability standardss
- Scalability and Performance: API Management allows organizations to implement features like API caching and rate limits to improve performance and prevent overconsumption of resources. This ensures that applications can handle a large volume of incoming requests without compromising on performance.
- Security: Managing API security is a critical aspect of API Management. It involves treating API tokens with the same level of security as passwords and considering periodic refreshes of API tokens to maintain cutting edge security protocols.
- Visibility and Control: API Management provides full visibility and control over API activity. All API requests and responses are logged, and the data can be streamed in real-time into third-party monitoring tools. This helps organizations understand their consumers better and plan the future of their API program.
API Management Key Concepts
API Management varies from organization to organization, but no matter what, it’s built on and around these key concepts:
- API Gateway: This is a crucial component for managing your APIs. It integrates advanced security, efficient routing, and effective mediation to ensure optimal performance and reliability.
- API Governance: This involves ensuring that your APIs are secure, compliant, and managed according to best practices. It includes activity auditing, versioning, and lifecycle management. Implementing granular access control and policies to manage usage and access is also a part of governance.
- API Design: This includes defining the endpoints, methods, and data structures for your APIs, for instance by using Workato’s native tools for API design and documentation.
- API Monitoring: This involves tracking and analyzing API usage and performance with comprehensive monitoring and analytics tools. A good API platform dashboard enables visualization of real-time data for your endpoints and API collections, including metrics such as response times, error messages, and traffic patterns.
- API Security: Security is key. Workato provides enterprise-grade security measures to securely expose your APIs. The API gateway supports various authentication methods including OAuth 2.0, JWT tokens, and OpenID Connect to ensure secure access to APIs.
- API Collections: An API collection is a set of endpoints that can be managed together. These endpoints can be API recipe-based or API proxy-based.
- Access Policies: These are used to set restrictions on the usage of an API. A single policy can be associated with one or more access profiles to enforce rate limiting and quota management.
- Access Profiles: A single client can have one or more access profiles. An access profile specifies one or more API collections to which the client has access and is optionally associated with an access policy.
- API Proxy: An API proxy is a gateway that separates a client-facing API from internal APIs. It allows for the secure exposure of internal APIs as endpoints while making use of management features provided by the API Platform.
These concepts encompassing the management, security, and monitoring of APIs to ensure they meet organizational needs and standards. They’re foundational to understanding how API Management works.
API Management Best Practices
API Management best practices are made up of a wide range of strategies and techniques designed to optimize the creation, deployment, and maintenance of APIs. APIM needs vary from business to business, but we’ve found the following best practices to be foundational for supercharged results.
- Understanding and Defining APIs: It’s crucial to start with a clear understanding of what an API is – a mechanism that allows two applications to exchange information using a set of rules. A clear understanding of foundational knowledge can help you think outside of the box for APIM needs.
- API Exposure and Management Goals: The primary goal of API management is to monitor API activity and ensure that the needs of developers and applications using the API are met. Exposing APIs can unlock new revenue channels, enable secure data sharing, facilitate real-time compliance, and more. It’s important to have a strategy for how and why you’re exposing APIs.
- Error Handling and Endpoint Naming: Implement graceful error handling to provide clients with proper status codes. Also, maintain flexibility in naming API endpoints to adhere to your organization’s standards. This helps in making APIs more intuitive and easier to work with.
- Versioning and Documentation: Maintain different versions of your API for backward compatibility and avoid forcing clients to migrate to new versions abruptly. Providing accurate and comprehensive API documentation is essential for enabling developers to understand and effectively use your APIs.
- Scalability, Performance, and Security: Consider enabling API caching for GET requests to significantly reduce response times. Set rate limits to prevent overconsumption of resources and ensure that your API can scale effectively. Treat API tokens like passwords and consider refreshing them periodically for enhanced security.
- API Collections, Clients, and Access Profiles: Organize your APIs into collections and create unique access profiles for each API consumer. This allows for better management of who has access to what and enables you to gather usage information on how your API endpoints are being used.
- Authentication and Authorization: Use secure authentication methods such as Auth Tokens, JWT, or OAuth 2.0. Implement access policies where necessary to control and monitor access to your APIs.
- Lifecycle Management and Governance: Manage the entire lifecycle of your APIs from creation to deprecation. This includes tracking performance metrics, ensuring security, and providing governance to maintain the quality and reliability of your APIs.
By adhering to these best practices, organizations can create, manage, and scale their APIs effectively, ensuring they meet the needs of developers and applications while maintaining high standards of security and performance.
Workato is a world class platform for API Management. Our APIM platform is built on these key concepts and has these best practices baked right in. To learn more, you can schedule a demo or feel free to talk to sales.
Want to see more? Try Workato for Free Today.
Learn how Workato can help you implement enterprise grade API Management solutions without having to write a single line of code.
