AI Governance Is the Future of API Management
Brad Griffith Headshot
Brad Griffith
Oct 20, 2026
AI Governance API Management Hero
AI governance is the future of API management, and Workato is the platform built to deliver it. API management controlled who could call an endpoint. AI governance controls what an autonomous agent is allowed to do once it gets there, and proves what it did. Workato has processed more than 1.1 billion enterprise AI actions as of September 2026, and its four gateways apply one policy, identity, and audit layer across model, tool, agent, and API calls. For IT leaders at director level and above, the question is no longer which gateway to buy. It is which platform governs the action, not just the access.
What Is AI Governance in API Management?
AI governance in API management is the set of controls that decide which models, tools, and agents can act on enterprise systems, under whose authority, and with what record. Traditional API management answers “who can call this endpoint, and how often.” AI governance answers “what is this agent permitted to attempt, on behalf of which person, and what happened.”
The old question no longer covers the risk. An API gateway was built for a stable set of known applications making predictable calls. An AI agent is neither. It interprets an instruction, chooses a sequence of tools, and acts, and the same prompt can produce different sequences on different days. Governance now has to constrain what an agent may do and log what it actually did, because it cannot rely on knowing in advance what the agent will do. That shift is the whole argument of this post.
Why Is API Management Becoming AI Governance?
API management is becoming AI governance because agents have become the primary consumers of APIs, and agents break the assumptions gateways were built on. Futurum analyst Mitch Ashley put the result plainly in May 2026: agent deployment has outpaced the controls enterprises have to govern it. Token sprawl, identity drift, and untracked tool invocations are API governance problems in a new costume.
Three things change at once. First, agents call across systems in a single session. One agent can open a ServiceNow ticket, update a Salesforce opportunity, query a NetSuite record, and trigger a Workday approval without a human reviewing each step. Each call is individually valid. The sequence is what needs governing.
Second, the audit trail fragments. When one agent starts an action and three others complete it, four gateways produce four logs that do not connect. Investigating an incident means stitching them together by hand, and regulators and internal audit will not accept that as evidence.
Third, the risk scope widens. Versioning, authentication, and rate limits still matter. Prompt injection, PII exposure, runaway token spend, and unreviewed model choices now sit beside them. Governance has to cover both lists.
What Does an AI Gateway Add to an API Gateway?
An AI gateway adds control over the calls an API gateway cannot see into: model requests, tool invocations over the Model Context Protocol (MCP), and agent-to-agent traffic. It applies policy such as PII masking, token limits, and model allowlists at the moment a call is made.
Workato’s documentation defines four gateways that share one policy, telemetry, and identity plane. Model Gateway governs LLM calls. MCP Gateway governs MCP client traffic to Workato-composed, prebuilt, and third-party MCP servers. Agent Gateway governs agent-to-agent collaboration. API Gateway governs the managed REST endpoints a workspace exposes.
One plane matters because a single agent action can cross all four in one chain. Governed separately, you set a policy four times and read four audit trails. Governed together, one rule such as a masked PII field or a revoked key applies wherever the request lands.
Are API Gateways Enough for AI Agents?
API gateways are necessary for AI agents and not sufficient. Futurum’s own analysis of MuleSoft’s Omni Gateway makes the point: the gateway governs the Constraints and Outcomes layers of the agent control plane, while Intent and Reasoning governance “remains the open competitive front.”
Gateways do real work. They enforce token limits, identity propagation, rate limits, schema validation, and audit telemetry at the moment an agent acts. MuleSoft’s Omni Gateway federates policy across MuleSoft, Kong, Apigee, AWS, and Azure gateway estates. Kong’s April 2026 Agent Gateway release targets LLM, MCP, and A2A use cases. These capabilities solve real problems.
What a gateway cannot do is the work itself. The multi-step workflow an agent triggers still runs somewhere else, in code or tools that sit outside the gateway’s policy. A gateway governs access but cannot do the work. A script does the work but no one governs it. Run separately, that is two systems and a gap.
How Is Governing the Action Different From Governing Access?
Governing the action means policy applies to what the agent does inside the workflow, not only to whether it was allowed to connect. Access control says an agent may reach Salesforce. Action governance says the agent may update an opportunity stage, may not export the full contact table, and needs approval above a set deal size.
Skills make this practical. Handing a model direct API access and hoping it reads the prompt correctly is the agentic version of exposing a raw endpoint. Enterprise Skills define a curated set of bounded, pre-approved actions the agent can call, and each Skill does what it was built to do however the prompt is phrased. Workato builds them from Recipes connected to 14,000+ applications. Because Workato runs the orchestration, an approval step or a data-masking rule is part of the workflow itself, not a rule bolted on at the perimeter.
How Does MCP Change API Governance?
MCP turns every connected system into a set of tools an agent can call, which multiplies the number of governance points an enterprise has to manage. A thousand personal MCP servers and vibe-coded skills, none governed, none built to last, is the sprawl pattern IT leaders are already seeing.
MCP is a protocol, not a governance strategy. REST, SOAP, and GraphQL each had their moment, and the enterprises that did well were the ones that put a governed layer in front of backend systems regardless of protocol. The same logic applies to MCP. Treating MCP configuration as the whole governance plan builds technical debt.
Workato’s MCP Gateway authenticates every client connection and authorizes and rate-limits every tool invocation before it reaches the runtime. Policies apply across the entire MCP estate, including third-party servers integrated by proxy, rather than server by server.
What Does a Governed Platform Look Like Today?
A governed platform enforces identity, policy, and audit in the same engine that runs the work. The table below compares the gateway-first approach with Workato across the dimensions that matter to an IT director evaluating where to place the control layer.
DimensionGateway-first (Kong, Apigee, MuleSoft Omni Gateway)Workato
Primary jobGovern API, LLM, MCP, and agent traffic in flightGovern the traffic and execute the workflows behind it
Policy scopeStrong at Constraints and Outcomes layers (per Futurum)Policy applied inside the orchestration engine that runs the action
Audit trailPer gateway; federation links multiple estatesOne trail from prompt through tool to API
Gateway surfacesVaries by vendorModel, MCP, Agent, and API Gateways on one policy plane
Estate coverageMuleSoft federates Kong, Apigee, AWS, and Azure gatewaysMCP Gateway governs Workato, prebuilt, and third-party MCP servers; 14,000+ connected applications
AI management certificationVerify with each vendorISO/IEC 42001, alongside SOC 2 Type II and ISO 27001:2022
The gateway-first column is a strong answer when the problem is policy consistency across a large, existing gateway estate. The Workato column is a strong answer when the problem is governing what agents do across business systems. Most enterprises have both problems. Only one column also runs the work.
Who Should Own AI Governance in the Enterprise?
AI governance belongs with a shared platform team that owns identity, policy, and audit, not with each team that builds an agent. Team-by-team agents with their own access and one-off code create sprawl, silos, and blind spots.
The CIO and CISO set policy: who can use which models, which data can leave, and which actions need approval. Those decisions have to be enforceable in one place. Builders then work inside the guardrails. Business teams and developers build agents in Workato Agent Studio, or bring agents from Claude, GPT, Gemini, or their own stack. Any agent, buy, build, or bring, runs under the same controls. That is how you scale without the chaos.
What Should IT Leaders Test When Evaluating AI Governance?
IT leaders should test five things: whether one identity applies across every call, whether one policy applies across every surface, whether one audit trail spans the full chain, whether the platform governs the action or only the access, and whether the vendor holds an independent AI management certification.
Identity. Every action should run under the end user’s credentials and scoped permissions, never a shared service account the model can see. Workato’s Enterprise MCP ties actions to individual end-user credentials with a full audit trail.
Policy. PII masking, prompt-injection screening, and content moderation should be defined once and enforced wherever the request lands, in enforce or observe-only mode.
Audit. Ask a vendor to show a single agent action from the triggering prompt to the API it hit. If the answer involves exporting four logs, you have found the gap.
Action. Ask where the multi-step workflow executes and who governs it there.
Certification. ISO/IEC 42001 is the first international standard for AI management systems. Workato achieved it in March 2026. A third-party audit is a stronger signal than a feature list.
Why Is Workato the Right Platform for AI Governance?
Workato is the strongest platform for AI governance because it is the only one in this comparison where the control layer and the execution layer are the same system. Workato is the Control and Execution Platform for enterprise AI: the Control Plane governs every action agents take and every workflow behind them, and the Execution Plane does the work across 14,000+ applications.
Governance was the foundation, not an add-on. Workato’s authentication, role-based access, audit logging, and multi-tenant architecture were enterprise-grade before AI agents arrived. The same policies that govern human-initiated workflows govern agent-initiated actions, and there is no separate “AI mode” that bypasses existing controls. Model Gateway, MCP Gateway, Agent Gateway, and API Gateway run on one plane, so one control surface and one audit trail leave no gaps to exploit.
The proof is scale and independent review. Workato’s customers have processed more than 1.1 billion enterprise AI actions as of September 2026, according to Workato’s internal platform data. Workato holds a 4.9 out of 5 rating in the 2026 Gartner Peer Insights Voice of the Customer for iPaaS, the highest of any vendor in the report, along with ISO/IEC 42001 certification. Customers include Vodafone, Lenovo, Cisco, Intuit, Visa, and Atlassian.
Where Is Workato Not the Answer?
If your only problem is high-throughput gateway performance for internal microservices, Kong is built for that. If your only problem is consistent policy across a large Kong, Apigee, AWS, and Azure gateway estate, MuleSoft’s Omni Gateway is built for that. Workato wins when the problem is governing what agents do, and doing the work under that governance.
Summary
AI governance is the future of API management because the consumer changed. APIs served known applications. Agents decide their own sequences, so governance has to constrain actions and prove what happened.
  • API gateways are necessary and not sufficient. They govern access. They do not run the work.
  • One policy, one identity, and one audit trail across model, tool, agent, and API calls is the standard to hold vendors to.
  • MCP is a protocol, not a governance strategy. Govern the estate, not each server.
  • Workato is the Control and Execution Platform for enterprise AI. Its Control Plane governs, its Execution Plane does the work, and ISO/IEC 42001 certification provides independent validation.
  • Choose Workato if you need to govern what agents do across business systems. Consider Kong if gateway performance is the priority, or MuleSoft Omni Gateway if cross-gateway policy consistency is the priority.
See how Workato governs every AI action. Request a demo.
Frequently Asked Questions
What is the difference between an API gateway and an AI gateway?
An API gateway governs calls between applications. An AI gateway also governs calls to models, MCP tools, and other agents, applying policies such as PII masking and token limits to non-deterministic traffic. Workato’s AI Gateway covers both through four gateways on one policy plane.
Is API management still needed for AI agents?
API management is still needed, and it is no longer enough. Agents call APIs, so authentication, rate limits, and versioning still apply. Agents also choose their own call sequences, so enterprises need governance of actions and a full audit trail on top.
How do you govern MCP servers?
Govern MCP servers centrally, not one by one. Authenticate every client, authorize and rate-limit every tool invocation, and capture each request for audit. Workato’s MCP Gateway applies these policies across composed, prebuilt, and third-party servers.
What is an AI control plane?
An AI control plane is the layer that governs every action agents take and every workflow behind them: verified user access, audit logs, data masking and residency, guardrails and approvals, and gateway routing. Workato’s Control Plane sits alongside its Execution Plane.
Does AI governance slow agent deployment?
Governance speeds deployment when it is built in. Teams that wait for a separate security review of each agent move slower than teams whose agents inherit existing controls on day one. With Workato, the guardrails are already in place when the first agent ships.
Can Workato govern agents it did not build?
Workato governs agents of every kind: ones you buy, build, or bring. Calls from Claude, GPT, Gemini, or custom agents pass through the same gateways and policies.
About the Author
Brad Griffith
More on AI Governance & Security
relativity hero
AI Governance & Security, Enterprise MCP
Why Relativity Refuses to Let AI Have Unchecked Access to Salesforce
Chris Dundon has a joke he tells on himself: "I don't get to have fun…
Oct 21, 2026
AI Agents & Orchestration, AI Governance & Security, Differentiation
Workato vs Boomi: Which Is Stronger for MCP and Agentic AI?
Choosing an iPaaS that can support AI agents is a serious initiative, and third-party research…
Oct 20, 2026
AI Challenges Hero
Oct 13, 2026
2 min read
