How to use dates in conditions
Conditions and unaccepted data types
When working with conditions in our recipe, we may need to work with different data types such as date, string, array, number, etc. However, depending on the condition that you have chosen, the accepted data type defers. This may pose a problem if the condition (e.g. contains, equals to, etc.) you need in your recipe does not accept your required data type.
Let’s say you only want to process events with a start date in the year 2022. This would mean:
- Trigger data: Start Date
- Condition: Contains
- Value: 2022
Here’s the problem – the trigger data is a date
data type while the chosen condition contains
only accepts array and string data types. However, I still want to check the date as a condition before moving forward with this automation. How can I troubleshoot this issue then?
“contains” condition only accepts Array and String data type
Back to basics: what are conditions?
Conditions are additional rules that you may add to control the flow of your recipe. This allows you to create more precise automations based on your business needs.
Let’s say you want to create a recipe that automatically escalates high priority
support cases to the engineering team by connecting Salesforce to Jira – in this case, you may add a condition that limits only case types of Priority
= High
to be processed in your recipe.
In your recipe, you may include conditions in both triggers – trigger conditions – as well as actions – conditional actions.
Left, trigger conditions, right, conditional actions
Related:
How to use trigger conditions to filter events
How to use conditional actions in your recipe
Different conditions and their accepted data types
Below is a list of available conditions and the data types accepted.
- contains – Array, String
- starts with – String
- ends with – String
- doesn’t contain – Array, String
- doesn’t start with – String
- doesn’t end with – String
- equals – Accepts all data type
- does not equals – Accepts all data type
- greater than – String, Date, Timestamp, Integer, Number, Boolean
- less than – String, Date, Timestamp, Integer, Number, Boolean
- is true – Boolean
- is not true – Boolean
- is present – Accepts all data type
- is not present – Accepts all data type
Depending on the condition that you have chosen, the data type it supports defer. For example, the condition contains
only accepts data types
Related: Understanding the data tree, data mapping, and data types
Using formula mode to convert your data type
Here’s how to troubleshoot the problem – use a formula to convert the current data type to your desired data type. Below, you’ll find a step-by-step tutorial on how to convert a date
data type to a string
data type.
In this example, we want to set up a trigger to filter for new or updated Salesforce cases that was last modified only in 2022. In summary:
- Trigger data:
Last Modified Date
- Condition: contains
- Value: 2022
Trigger condition that filter for cases that was last modified in 2022
Related: How to transform dates with formula mode
Step 1: Change to formula mode
With your chosen datapill already selected, toggle to formula mode.
Toggle to formula mode
Step 2: Use the formula .to_s
To convert your date
data type, enter in the formula .to_s
to the back of your chosen datapill.
Step 3: Save your recipe
Click save and test your recipe.
Congrats! You should see a successful test job.
Successful test job after converting data type
More resources
Read the full documentation on the .to_s
formula.
