Changelog
Keep up with the latest updates we’ve made in Workato.
Changelog
Mar 26, 2025
Released
OPA 27.0 is released
OPA 27.0 delivers key updates across SMB, Kafka, SAP, FTPS, and configuration—focused on improving compatibility, security, and flexibility.
  • New on-prem SMB adapter enables direct network share connections without OS-level drive mapping. Supports cross-domain access on Windows and Linux.
  • Added JSON format support in schema registry, alongside Avro and Protobuf.
  • Upgraded to SAP JCo 3.1.11 with legacy JCo 3.0 compatibility and added a “Detail” field to Check IDoc Status for clearer error insights.
  • Config.yml is now optional for cloud profiles; a config.yml.sample is provided with restricted default permissions.
  • New JAVA_OPTIONS variable supports custom JVM parameters on all platforms.
Learn more in the OPA 27.0 documentation.
Jan 27, 2025
Released
On-Prem Agent (OPA) 26.0 Release
We are excited to announce the release of OPA 26.0, which introduces a unified package for enhanced compatibility and bug fixes to improve connectivity:
  • Unified Package for All Data Centers:A single package now supports all data centers globally. Previous packages with region-specific suffixes (-eu, -sg, -jp, -au) will continue to work but are no longer published.
  • Windows FTP Fixes: Addressed bugs affecting compatibility with Windows-based FTP servers, ensuring smoother and more reliable file transfers.
Thank you to the OPA/SAP team and everyone who contributed to this release!
Learn more in our On-prem Agent Version documentation.
Dec 18, 2024
Released
On-Prem Agent (OPA) 25.1 Release
OPA has been updated with the following enhancements and fixes:
  • Kafka: Improved trigger throughput.
  • FTPS: Added session resumption support for TLS 1.2.
  • SAP: Fixed duplication of IDoc types with custom extensions.
  • SAP: Enhanced recognition of IDoc statuses for the Send IDoc action.
  • Security: Updated libraries according to the OWASP scanner recommendations.
See the OPA release notes for this and previous updates to OPA.
Nov 6, 2024
Released
On-Prem Agent (OPA) 25.0 Release
The latest release includes on-prem FTP support plus SAP changes. Updates include:
  • FTP: Added support for on-premise FTP.
  • SAP: Provided detailed error messages for known SAP JCo failures.
  • SAP: Uses the latest schema for RFC, BAPI and IDoc without restarting OPA.
  • SAP: Extended timeout for updating outbound IDoc status to ensure stability on poor network connections.
  • SFTP: Improved logging for troubleshooting purposes.
  • MSSQL: Fixed issue when connecting to SQL Server with Windows Authentication.
  • Logging: Fixed repetitive Request has Been Canceled errors in logs.
  • Security: Updated JRE to 21.0.5+11, Jetty to 12.0.14, Spring to 6.1.14, and other libraries according to OWASP recommendations.
Aug 23, 2024
Released
On-prem Agent (OPA) 24.3 Release
OPA has been updated with new SAP and security capabilities:
  • SAP: Aligned order of fields in RFC_READ_TABLE requests for compatibility with legacy SAP systems.
Jun 28, 2024
Released
On-prem Agent (OPA) 24.1 Release
OPA has been updated with an important SAP feature, and an SAP bug fix:
  • SAP: Improved Call BAPI action, allowing easier navigation in the catalog of available BAPI methods.
  • SAP: Fixed loading of IDoc segments. Added support for segment nesting levels up to 128
Jun 10, 2024
Released
On-prem Agent (OPA) 24.0 Release
OPA has been updated with a new version including the following bug fixes and library upgrades:
  • SFTP: Added support for on-premise SFTP.
  • SAP: Removed the metadata cache for IDoc types. All required data is now retrieved on-demand from the SAP server. This change saves agent memory and improves operational consistency.
  • SAP: Added support for SAP JCo version 3.1.9 (2024-03-19), including the sapjco3.jar and corresponding native binary libraries. While Workato recommends using the latest version of SAP JCo with OPA, we still support older JCo versions with the major release 3.0.0 in partial compatibility mode.
  • SAP: Added support for more precise identification of the Distribution Model for Inbound IDocs.
  • Cloud logging: Fixed a bug that caused log spamming when debugging was enabled.
May 20, 2024
Released
On-prem Agent (OPA) 23.2 Release
OPA has been updated with a new minor version including the following bug fixes and library upgrades:
  • Security: updated Java runtime and libraries according to OWASP scanner recommendations.
  • Database: fixed bug when agent becomes unresponsive when database request is canceled.
  • Cloud logging: improved data transfer algorithm to reduce losses when a lot of messages appear.
  • Linux: fixed bug where logs were not produced after package upgrade.
Mar 27, 2024
Released
On-prem Agent (OPA) 23.1 Release
OPA has been updated with a new minor version including the following improvements:
  • Kafka: improved trigger stability in case of network failures.
  • Kafka: updated Avro to 1.11.3, kafka-avro-serializer and kafka-protobuf-serializer to 7.6.0.
  • SAP: optimized memory usage of metadata for RFM and BAPI.
  • SAP: fixed bug when RFM name contains unsafe URL characters.
  • Database: added support for synchronous actions cancellation.
Feb 9, 2024
Released
On-prem Agent (OPA) 23.0 Release
This OPA release has a number of bug fixes and updates to keep things humming along:
  • Kafka: added support for Protobuf schema format.
  • HTTP: the agent now correctly handles cases where the remote server responds before the request completes.
  • HTTP: requests can now pass through a configured proxy server.
  • Hardening: fixed bug where agent failed to reconnect when using a proxy server.
  • JMS: fixed message parsing when sending from non-JMS applications.
  • TLS: added support for ECC private keys and certificates.
  • MS SQL: fixed connection problem when using ActiveDirectory authentication method.
  • SAP: implemented sending IDoc batches to Workato webhook.
  • SAP: support for receiving outbound IDocs from SAP for all partner types.
  • SAP: keep NUMC data types as strings instead of integers.
  • Security: updated Java to version 21.0.2+13.
  • Security: updated Spring Framework to version 6.1.2, Spring Boot to 3.2.2, AWS SQS messaging library to 2.1.1
2025
Q1
2024
2023
2022
2021
2020
2019
Q4
Q3
Q2
