Advanced data transformations with SQL, Python, and Javascript
Register to watch on-demand
Transforming data is an essential part of your integration and automation project. Workato provides a rich set of formulas, regular expressions, lookup tables and in-memory databases for transforming data.
Occasionally, you need to step outside of the tools available in Workato and bring in other languages/tools of choice, such as Ruby, AWS Lambda, JavaScript, Python, SQL or others to create custom transformations.
The ability to create custom transformations using a scripting language gives you the freedom to extend the platform to fit your unique needs.
Join this Product Hour to learn how you can use a combination of built-in and extensible transformations to normalize and cleanse data; parse unstructured data and create structured output; join, merge and aggregate data from multiple sources, and more.
What will you learn?
- Data cleansing, validation, and enrichment
- Merging and joining data from multiple sources
- SQL transformations for high volume operations
- Pushdown SQL transformations for ELT
- Custom transformations with Python, Javascript
